I am putting "sit up straight" bars on my ride. (off an old goldwing) I need throttle/ choke cables about 10 " longer to stay with stock routing. Any ideas?
You shouldn't need longer throttle cables. I have GL1200 bars on my bike and I was able to reroute the throttle cables. You will need longer brake, clutch and choke lines (cables).
I got mine from Murph http://www.murphskits.com/ Just need to email him how much longer than stock you want them.
