jacksdad1963
Moped
Hi, stripped my 1994 A9 front forks today, very easy job.
Following on from the posts on here, I'll add that the nut used to hold the damper rod is 24mm, which threads onto M16 bar. I bought 6x nuts and a metre of threaded bar from my local fastener stockists for £4.00, can't beat our local small shops ;D
I tried to unlock the allen key from the fork, but I kept undoing the nuts...waste of time! Finally welded up 2 nuts onto the end of the M16 bar, then easily got things apart, with the use of a vise to grip the bar.
I've now found some scoring on the base of each leg, which although visible, isn't deep, just about feel the score lines with a fingernail. I've ordered a rebuild kit ( both bushes, oil seal and dust seal and 7.5 weight oil) but will the legs be good to re-use? If so, should I position the worn area at the front of the bike?
