I used a mounting bracket similar to MOB's but made out of a 90* flat bracket. Worked great,
but then I got tip over bars, and mounted the driving lights to the bars... Tip over bars
are expensive light brackets (actually you need t/o bars AND brackets), but do serve another purpose...
they also hold the highway pegs!!
