Gents
For those in the know of the finer points....
On my 2014 C-14 I know there is a light parasitic power draw when the key is off. I've been leaving a Battery Tender Jr, 750 ma., hooked up to it.
When it's hooked up the voltage reads 13.2 V. Is this Ok long term? When I fully charge the battery and disconnect the ground lead the battery settles down at 12.8 for about a month and then goes to 12.7.
I've noticed that when I disconnect my batteries for the winter lay up and charge them once a month they seem to last much longer.
On another bike I left this charger on for the winter and the battery, a flooded lead acid, ran dry and ruined it.
Then this spring on another bike I left this charger on, for the winter, a sealed lead acid battery and it failed at the 24 month point.
Am I killing my batteries by leaving them hooked up at 13.2V all winter?
When my C-14 is running, FWIW, the voltage is 14.4V which is normal I believe.
Thanks in advance!
Nick
2014 C-14
Thanks in advance!
Nick
2014 C-14
