I know there are a ton of threads on each topic but interested in polling the group here for the latest recommendations.
Please vote and post your brand/type of mod you recommend.
I resisted getting a flash on my last bike. Decided to try it out on this one. I would highly recommend it. I did not know what to expect when I went on my first ride with the flashed ecu yesterday. This bike, in my opinion, is incredibly smooth stock. The first thing I noticed was how much more smoother it is now that it’s flashed. The throttle response is a drastic change for the better on a flashed ecu. The smoothness continues with the power delivery. I was unintentionally going much faster than I thought while riding. I used to get some buzziness at certain cruising rpm’s which is completely gone now. And I never thought the jerky/snatchy throttle was a problem on this bike until I tried it without. I was a skeptic on ecu flashing and now I am a believer.Lol....
Id be negligent in asking how old, tall, and (gulp) weight you are to render a educated vote.
If your older than 50 and have short legs with a 200 lb frame, i would vote towards crash bars cuz you ARE gonna drop it sooner or later!
Protect that radiator..! Oem replacements are north of $700.
When i bought my 2010 (used) it came with a hard seat, risers, and a radiator gauge. My first upgrade was canyon cages. I was 55 when i got it. Im 5'10 31 inch inseam and 210 lbs. Piece of mind in case i drop her, (and i have) saved me big bucks not having to repair/replace plastic. Added benefit was a place to mount auxiliary lighring and highway pegs.
I then changed seats (several times) and imho if you plan on doing any long distance riding, go directly with a Russell day long...
Personally I've resisted the urge to flash, er get her flashed, cuz i like her just the way she is. Many many coggers have had them flashed and love the transformation.
Ive also gotten rid of my risers and gone with helibars. They are adjusted perfectly so i have no more neck pain or hand cramping..
Maverick you’ll love it - Nick on the C-14 it’s a fun / game changer. I’ll share with you my settings, VERY easy to follow directions to adjust with an IPhone or Android.I'm getting ready to install one on my dorsoduro. basically plug into your coil packs and into the ignition and when you up shift it take spark away for a split second to unload the transmission so you can shift with no clutch. it engages via a sensor or shifter linkage rod
here is a dorsoduro with the upgrade
Dropbox - File Deleted - Simplify your life
www.dropbox.com
I'm running these as well. You have to see the improvement over stock bulbs in person to even believe it. Worth every penny for sure.View attachment 30871
Auxito LED lamps are the option I went with. Powerful and direct replacements for the OEM halogens. A little pricey but WELL worth the modest investment. Highly recommend!
Yes. These fit just like the stock bulbs.Rubber boot fit over with no mods?
I went on Amazon to check out those Auxito bulbs. It said will not fit my 08 concours. Am I missing something?
Thanks for the tips on the LED bulbs. I have always been hesitant to install untested brands/models until others have tested in the specific headlight housing/reflector and verified the beam pattern is not garbage... unless it's made by a very reputable company ($$$) specifically for that application, and generally these companies would choose sell you a whole new housing for the most improvement.
I ordered both headlight and city Auxito bulbs from Amazon. I appreciate that they call out in pictures that the LED placement is the same as the filament in a halogen bulb. I installed these last night, and WOW they are bright! The beam pattern looks like it might bleed up just a tiny bit from the stock halogen H4 bulbs, but I'm less concerned about that on a motorcycle than I would be on a car. The color is nice too, not blue at all, just white.
My stance for motorcycles is that even if I'm annoying oncoming traffic a little bit, at least they can see me, and that's better than the alternative!
Riding today, I was thinking a heated seat would be pretty nice- Good tool kit for on the road
- Oil Filter Guard (I have put a hole in my oil filter from debris in the road)
- Radiator Guard (I have put a hole in my radiator from debris in the road...different from above)
- Tip Over Bars (Damaged plastics are expensive)
- Flash for sure if you can get it
- Seat, Cruise Control, and Heli Bars if you ride long distance
- Suspension if you are a spirited rider
My 2 cents.
Heated pants cover more adequately and cost less.Riding today, I was thinking a heated seat would be pretty nice
So far, ive done just a flash and the risers and I am really happy with the bike. I have no pressing urges to upgrade anything else but we'll see how I feel after full break-in.
I know a lot of people focus on the exhaust. Curious though if there are any potential changes to intake that could be made?
