I have to admit this is one of my fav mods. 2003 Concours, 49K COG #6953 IBA 28004 http://mysite.verizon.net/slybones/Concours/connieMain.htmMy son has a set on his 86. He rode my 90 yesterday and the first thing he said when he got off was "You have got to get a set of those brake brackets for this thing even if we don't have 4 pot calipers yet."
Ebay !! http://tinyurl.com/qrgr8x http://tinyurl.com/qrg8ed The one's I got were Nissin, they fit a 1999-2006 CBR 600 F4, I think the GSXR 750 from 2001-2003 will also fit. There does not seem to be much difference between the Nissin and Tokico calipers. I emailed Shaun and let him look at the calipers on Ebay to be sure they would be ok. I got the brackets today,,they look SWEET !! I'll post some pics when they are installed. Check with Murph also, I know he had some left a while back but was running low, he sells the whole package I think, calipers,new pads and lines. Because of low farcle funds I'll put the braided lines on later http://www.murphskits.com/catalog/ I think you need to email Murph about the calipers. CT AAD COG #7011-A 2003 Concours-Mary Ann 1995 Honda Nighthawk 750 wifesNow which kind nisson, tokico, something else?? Where do you get them?? What bikes do they come on.
While I cannot answer your question about the caliper adapters, I maybe can offer a little insight to your parenthetical question...Slybones said:I need to lay off the martini's at lunch. That link takes me to this same thread. For those who dont use the listserv what is the answer ( what is the listserv anyways ).
wingboy said:Bought the adapters from SVR page and Tokico calipers from GXR 600, well they fit but mounting lugs are thicker on Connie so I must make adapters, now I look for DL650 to measure the difference. Keep you posted when I am done.
xjdaver said:I'm wondering if the SVR adapters will only work on 94 and after.
wingboy said:Well I mounted and aligned the calipers using standard M8 washers and everything works fine. I just have problems with my brake hoses as caliper is sitting lower and I can't use my Galfers nor the ones that came with calipers from GXR as they are too long -2 line design so I guess I have to call Murph and ask for custom ones. I still have to rebuild calipers and put new brake pads but even now breaking seems to be more powerful. I also think I will actually replace washers with custom made spacers. Overall not cheap upgrade but worth the money.
BratmanXj said::TPIWWP:
wingboy said:Centex, the "excess of the pad is outside the rotor. The adapter was designed for 310 mm rotor, Connie has 300 mm.
WillyP said:I believe it would only be an issue if the pads were so worn that the overhanging material came together and prevented the pads from clamping the rotor. The pads would have to have half the thickness of the rotor worn off each one for that to happen. Then you could probably just drag a file across the ridge. Or just replace the pad, at that point.
Slybones said:And while using them on the 320mm is better braking and less side effects
BratmanXj said:Slybones said:And while using them on the 320mm is better braking and less side effects
Less - so going to the 320mm rotors does not completely alleviate the pad overhang?
2linby said:Fred,
Thanks for posting the pictures. With my 4 pot Tokicos the overlap is even greater and yes, I've "trimmed" the excess twice already using a bench grinder.
Slybones said:With regards to 4 pots designed to make use of the full area of 320mm rotors, you are saying they can be used on 310mm rotors and have no overhang AND be properly aligned on the inside? IE work perfectly, no funky pad wear.
OR ????
2linby said:Are there any 310mm rotors that can fit the Connie?
Slybones said:Thanks GF, that clears up my 4 pot confusion. Out of curiosity any tidbits like that for the 6 pots to complete the picture.
GF-in-CA said:2linby said:Are there any 310mm rotors that can fit the Connie?
Bob, the bikes that have 310 mm rotors with the same offset and bolt pattern as the later C10 are:
ZX 750 H1/H2 (ZX7) 89-90
ZX 9R (ZX 900 E1/E2) 00-01
ZR 1100 A1-A4 Zephyr 92-95
ZR 1100 B1 Zephyr 96
ZX 1100 C1-C4 (ZX11) Ninja 90-93
ZRX 1100/ 1200 any year
!!INTERESTED!!2Fast said:On a similar note, I have some brackets being made right now for the pre 94 models, to convert to Tokico 4 pots and 320mm rotors. More soon!
Brian
Here's a teaser shot of the new and old.kd50 said:!!INTERESTED!!2Fast said:On a similar note, I have some brackets being made right now for the pre 94 models, to convert to Tokico 4 pots and 320mm rotors. More soon!
Brian
