jfryhayes@aol.com
Training Wheels
Hi all. During an oil change last Friday the upper left motor mount bolt presented itself. It was protruding from the head, snapped at the base of the nut. Nut and shim are gone.
I have a bit of half inch pipe and a bolt (poor mans emergency foot peg - don't ask) rattling around in the glove box, so I'm insure how long I've ridden with the broken bolt.
Two questions;
What other areas of the motorcycle should I check for related issues?
I'm speculating that someone tightened the bolt without a torque wrench and possibly other bolts may preparing to snap also. Does it make sense to re-torque other mount bolts or is that inviting trouble?
Also, - Ok three questions- regarding the shim. Feeler gauge measures 1.9mm between frame and head. The shim is supposed to be 1.2mm. That's not an issue - is it?
Thanks
Two questions;
Thanks
