I tow a Cycle-mate 2000 LTD cargo trailer using a hitchdoc vertical receiver style hitch. www.cycle-mate.com www.hitchdoc.com Towing a trailer is certainly different than not. Considerations are braking, speed, manuverability, , handling, parking and being dorky. You have to adapt to the differences in handling towing a trailer. Using the "middle" of the road more so than the "edges". Anticipating issues before they occur and understanding the need to brake early and often. Loading and wieght distribution of the trailer can make it enjoyable or a nightmare so learn to pack with care. Reduce tongue weight to 10% of the overall load and you'll be happy. Other questions I can try to answer direct. AKA "2linby" That's 2-lin-by folks! Northwest Area Director COG #5539 AMA #927779 IBA #15034 TEAM OREGON MC Instructor http://community.webshots.com/user/2linby http://tinyurl.com/njas8 (IBA BunBurner Gold Trip) http://tinyurl.com/lwelx (Alaska trip)
Yep, I 2nd what that 2lin guy says! For the most part you won't know it's there, till you use your brakes. Dave Muir 1980 LTD1000 - Rocket 1999 Concours - Rocket II 1997 Dyna - wife's CT-COG #3649 Merchandise Czar
I think it can do it. Check it out. http://www.flickr.com/photos/20211686@N05/3007587347/ ---------------------------------- I will answer any question. It is up to you to figure out if I should have.
As with most vehicles the problem is not pulling the trailer but stopping it. I've been kicking around the idea of getting a unigo myself one day. Thou not very big and kind of pricey, they just seem like they would work very well. But as mentioned before you simply have to allow more stopping distance and keep in mind that you've got the extra weight..
The key item is the weight of the trailer. I tried to pull an Aspen Classic Camper trailer with my connie. It pulled easily when going straight, but if you were taking off and in a curve, you could feel the mass of the trailer pulling against your balance. It feels like it is trying to pull you over, a very weird feeling, but physics prevail and you stay upright. Also as mentioned, braking is the item you most have to worry with. I'd guess that anything over 150 lbs you might want brakes on the trailer. As for the camper, I now pull it with a K1200LT and I don't get that feeling of it trying to pull me over in a curve. Also, it does have electric brakes and there is an electronic brake controller on the bike, makes a world of difference. The best advice I can give you, is to go for the lightest and smallest trailer you can possible get by with. As for the trailer hitch, Hitch Doc makes one that goes on fairly easily. There are also other brands, but most are basically the same design. The item I would be most concerned with is the height of the hitch from the ground. I like the center of the ball to be slightly below the center of the rear axle. tcars, John, Rallymaster 2009
I tow a bushtec turbo +2, actually all over the northeastern U.S. and I haven't had any problems. I do agree about the braking but it won't take long to get used to, use your head. {http://good-times.webshots.com/photo/2391627380104341151NmGksA}
Wife and I both pull Uni-go's behind our C-10's, you don't even know they are behind you. Kurt & Sue Nordstrom Spotsylvania, VA COG 6049 & 6049A VA & WV Assistant Area Directors
Pulling trailers with other bikes (water cooled bikes) I've experienced engine temps that ran a bit higher than I liked. Any problems in that area with the Connie?' Sahagan
I HAVE PULLED A 1980'S TRAILER WITH MY 2000 CONNIE FOR SEVERIAL TRIPS. I AGREE ABOUT BEING CAREFUL ABOUT BRAKING. I HAVE A VERY HEAVY TRAILER AND HAVE HAD PROBLEMS WITH THE RADIAL TIRES COMING APART FROM THE ADDED STRESS ON THE TIRES. I AM USING BIAS TIRES AT THE ADVICE OF A FRIEND. I ALSO RECOMEND THE OVER SIZE FRONT BRAKE ROTOR KIT FROM MURPH'S BECAUSE MY ROTORS WARPED FROM HEAT OF BRAKING WITH TRAILER. I HAVE HAD NO PROBLEMS WITH THE ROTORS SINCE CHANGING ROTORS.
I pull a Bushtec Turbo+2 trailer and have a Hitchdoc hitch installed. I also agree with what everyone else who is pulling a trailer has said. I've pulled other trailers before the Bushtec and I must say that this is the easiest pulling trailer in my experiences. But you still have to remember it's there when it comes to stopping, allow extra distance! Keeping it loaded properly with the proper weight balance also makes a big difference.
