I have a Ninja 250 tank in good condition if you consider one. I was going to mount on right side and it will fit nicely right against the battery box and can access easily when side panel is removed. Then you still have the tool tray intact
I went half naked for 2 reasons. 1. My bike was wrecked / the bottom fairings were scratched / cracked and whoever installed the tip over bars cut big round holes in the side fairing rather than fitting them thru the vents. It looked like crap. 2. The Connie was jus too hot - lotta heat...
forum.concours.org
If link doesn't work I can post pictures for ya here
Best
Bob
