Octane it's all about the altitude. 6000 ft doesn't need the same octane as sea level. When traveling I pump the best I can get and don't worry about it. But will admit the -09 seems to run better on pure premium which around here is 92.
I own a 1942 John Deere D which probably would run on 40 octane.
That all said be careful not to do a review here. There is a review board for that.
