Having a brain fart.
Disconnect battery and not sure if one wire should be attached to the positive or negative post.
Comes from seat side of battery box,
The wire is black with yellow strip covered by a 1/4” diameter black plastic sleeve.
Don't forget to clean up all the connections, both sides of each ring lug going to the frame ground should be clean, the brass should be bright when done and the connection point on the frame nice and clean.
