Sounds easy right? Its not as easy as plug and play sounds, mine is on the bike and it works about 90% .Thought the mccruise was supposed to be plug and play?
Curious what doesn't work on yours? Mine works flawlessly, though it definitely took some fine tuning right after install to get the 'feel' correct.Sounds easy right? Its not as easy as plug and play sounds, mine is on the bike and it works about 90% .
Probably needs a fine tune, everything does what it should BUT, It won’t disengage the cruise control when I pull in the clutch and I really have to get on the brakes hard in order for it to disengage the cruise control,I would think like a car you just touch the brake and it shuts off but that isn’t the case with mine, i can’t hear a good enough on the telephone to talk to the people overseas on how to solve that problem so I just always have my finger ready to turn it off.Curious what doesn't work on yours? Mine works flawlessly, though it definitely took some fine tuning right after install to get the 'feel' correct.
Stuff happens. When I worked at GE, we made a bunch of shaded pole stators without any shading coils. For some reason, they failed the quality control check before they shipped.Hmm. A buddy if mine put one in a friends c14. Dam thing wouldnt work. They called tech support and after going thru all the connections, it was discovered that 2 wires had been installed by mccruise in wrong locations in the connector. Wires were moved to their correct locations and it works perfectly..
