I've done it a dozen times and struggled almost every time - but the pads do come out with a little finesse. It's sort of like those bar puzzles. Sorry I couldn't be more helpful but your question has sat unanswered for too long.
Can be a PITA. Try to concentrate on one side first, rocking the pad as fas as possible until it slips over the end of the pin - then - work on the remaining side.
