Need kipass ecu with registered fob
Olds7268
Yes, once again I am looking for the Kipass e c u with a registered fob. This will be the third one that I bought so hopefully I can find a good one. Thanks
Yes I am parting the bike out. I want 500 for the KIPAAS ECU, two fobs, the seat latch lock and any other ignition parts I have that you need to get your bike running.
I am using the tank and body work and brake calipers and master cylindars on my 08 so those are not for sale.
Ok. Let me see what I can put together
So I am selling the ignition/KIPASS components including the steering lock unit. I have the upper steering stem off and it looks like the lock unit is attached with two bolts on the underside with the heads broken off for security.
The manual reads as follows:
Steering Lock Unit Replacement
•Remove:
Steering Stem Head
Using a small chisel or punch, turn out the Torx bolts [A]. •Remove the steering lock unit
. Has anyone done this? I am a little dubious about "turning out" the bolts with a small chisel or punch. With my luck I'd break both parts.
