What does ECO mode do with MRP?
fastenova
Well I assume more than just physically having O2 sensors, it's the difference between closed loop and open loop. In systems without O2 sensors it's always OL, so you can set the desired fueling and that's pretty much it.
In a CL system (with O2 sensors) there's only so much tuning you can do as it will tend to "learn away" any changes in its attempt to get back to factory spec'd AFR. In cruise conditions (arguably where the most fuel economy stands to be gained) a CL system will always utilize the O2 sensors, and will only use the fueling tables without input from the O2 sensors at WOT.
Steve in sunny Fla
Iron Butt
Industry Vendor
2 of my 3 flashes for 2015 up are closed loop, and they work great. You can probably figure out how I negotiated that.
Steve
mrinnocent
I took the bike out today and did some testing with a free GPS drag timer app. I found two freeway exits and did a 30-75 mph run between them, with times and distances gathered for 30-50 mph and 50-75 mph. I did runs between them and recorded the results after each run.
Testing protocol:
- Eight total runs, four in each direction with four in each mode (see chart).
- Enter freeway at below 30 mph in 3rd gear with clear traffic and dump the throttle into wide open until exceeding 75 mph.
- No gear changes, ending the sprint in 3rd. This eliminates a variable.
- Configuration: screen low, riding solo, side and top cases on and empty, 91 octane gas.
- Weather: clear, late in day, temperature ~60F.
- All speeds were legal in the jurisdiction where testing was performed.
Results:
- Normal mode was faster on average than ECO mode in both 30-60 mph and 50-75 mph sprints.
- Normal mode took the same distance in 30-60 mph sprint but less distance in 50-75 mph sprint.
- There was a lot of variation in the results.
Potential sources of error:
- Dumping throttle rather than rolling on tended to bog the motor
- Speed at which throttle was fully opened was not always the same
- The GPS app may not be all that accurate
- Motor was getting hotter toward the end
Conclusions:
- Anyone familiar with statistics will note, there aren't enough samples to come to any confident conclusions.
- The 50-75 mph sprint numbers are probably more reliable than the 30-60 mph numbers since they are less affected by roll-on speed and technique.
- There's enough noise in the numbers that technique and circumstances are likely more important than the different between the ECU maps, if there is any.
- Further research is needed.
Steve in sunny Fla
Iron Butt
Industry Vendor
Testing protocol:
Results:
Conclusions:
Some real inconsistency with those results though. Look at run #5 in ECO... it covered the 30-60 mark in the shortes distance of 190 ft, but took 3.9 seconds to do so? Compare to Run #2, which covered the next shortest distance at 207 ft and did it in 2.8 seconds. Somethings way off there. Also, the ambient temp corrections don't stabilize until about 77 tp 8 degrees, below that the fueling is being richened.
Glad to see you being curious though. It's fun.
Steve
Scary Harry
Fear is not boring. COG# 4090
Steve,
I have about a 20 mile one way ride to the local Walmart. I can just alternate back and forth between ECO/STANDARD and reset the MPG reading after each round trip. How many round trips do you think it will take to see a significant difference? I figure the MPG meter doesn't need to be real accurate, just show the difference between modes. The majority of the route is 65 MPH (14 miles), then 55 (5 miles), down to 45 before entering the parking lot.
connie_rider
I can't find the post where Mr Innocent tells us how he is riding? (during normal riding)
(Perhaps Steve is talking to him and got it there)?
He did attach a (source) in which Kawasaki answers questions about their bikes.
That source is pretty informative.
It sez; By pushing the handle switch, riders are able to activate the Fuel Economy Assistance Mode, switching the ECU to a leaner fuel map in which ignition timing and fuel injection prioritize fuel economy.
ie; It sez it's a "leaner fuel map" in which "ignition timing and fuel injection" prioritize fuel economy.
So;
"Ted" may have been right that it is not a Stand-alone Map, and adjusts only a few things.
But, "Ted" may be wrong that it doesn't have its own numbers to control those few things {??}.
zarticus
"By pushing the handle switch, riders are able to activate the Fuel Economy Assistance Mode, switching the ECU to a leaner fuel map in which ignition timing and fuel injection prioritize fuel economy."
It does not say by pushing the button the bike "modifies" the bikes map, It says it switche to a leaner fuel map
connie_rider
Zarticus/Agreed; That is why I sed; But, "Ted" may be wrong that it doesn't have its own numbers to control those few things {??}.
NOTE: I don't know how a MAP actually controls things. {Only a programmer can tell us how it operates}
In this case;
ECO may have a preset number/value that it uses, (Marty Theory)
"Or" ECO may have a preset Percentage that it uses. (Ted Theory)
If ECO "goes to" a number, that number is in the ECO Map.
If ECO "adjusts from" a number, (that number is in the Normal Map) and is changed by the percent of change that is in the ECO Map.
Testing protocol:
Results:
Conclusions:
(Background) I did thousands of Accel tests {on a Dyno} when I worked at Shell.
We discovered that the slightest variable can make a huge difference.
So, I don't think his deviations are that bad. (considering how few and how he had to do the tests)
With only a few tests, they do indicate a difference in Normal and ECO.
Question; What RPM's was the engine turning at 30 MPH?
You said that the engine bogged if throttle applied too quickly?
In the Roll-On Comparison tests, we're intentionally starting from 2000 RPM in 3rd gear with no Bog.
Assuming that your above 2000, your engine shouldn't have Bogged down.
Scary Harry
I SWARE...this is like comparing top shelf wine to the bottom shelf wine.
All I know for sure is I'm not cracking skulls with my rider and I'm not being thrown over the handle bars during deceleration with my MR flash.
I'm going to collect data using my riding style to Wally Wurld and back, and report back if I survive the weather, scamdemic, drunk drivers, deer, and other undesirables.
mrinnocent
I agree, the numbers really call into doubt the data gathering method, which was the free app I used. Probably a dedicated Dragy device would do the trick, but tbh I don't feel like spending $160 to find out.
Also of note, the eastbound runs had me come off a cloverleaf and go under an overpass, which could easily mess with the GPS readings, which are already unreliable for this kind of work.
If you can reset the average fuel economy in the display (I forget if that's possible), I think you should see a pattern emerge within 8-10 readings, so 4-5 in each mode. Sort of like when you zero a rifle, there's always a flyer, so four minus the one flub will give you three readings, which to me is the absolute minimum (even when your rounds cost $2/ea or your gas is $5/gal).
But if you are doing trips on different days, you'll have different bike configurations and ambient conditions, introducing noise into the results. You can see from my own results, gathered as consistently as I could, the numbers were all over the place. If you really want an answer you can trust, you either need to get lots of readings (like dozens) over time, or a handful of really consistent readings for a given set of conditions.
In my OP (ECO vs normal, 2-up on same day) I was riding sedate, with occasional blips to scare my wife, with about even miles split between freeway, twisty backroads, and very twisty paved mountain roads (single lane, 1st gear switchbacks, occasional washouts).
As you've gathered, while the Kawi statement is indicative, it isn't authoritative. It's just ad copy. I'm imagining the engineer said something to the PR person, and that got translated into whatever they submitted just before deadline that day. Is that really how Kawi rolls? Who knows. I just consider the statement to be a data point within a larger narrative that we are building in order to get our mental models closer to reality.
Steve in sunny Fla
Iron Butt
Industry Vendor
For a fact, Kawasaki has no problem engaging in dis-information.
Steve
zarticus
I have had that I remember at least 6 variations of flashes, I currently have the Hammer & it continues to blow my mind how much power my bike now has !. With all variations of flash I have always got better MPG with ECO mode on the Highway and using my Rostra Cruise control. Literally thousands of miles on trips.
Steve in sunny Fla
Iron Butt
Industry Vendor
no kidding... you were there right from the start... we sure did plenty of roll - ons during the initial building phase! Do you have an idea how much better the eco mileage is on a cruise vs the flash on a long haul? I personally have only seen about a 2 mpg gain, and that was more with my newer flashes, the early ones were pretty tightly tuned afr's for economy - as you know!
Steve
zarticus
Steve
Only by on average 2-3 MPG. Cruise set between 70-75. I only use ECO on long trips on the Highway, Other than that I always leave it set on the Hammer flash. The different Flashes always got the same or better MPG than the factory regular flash. Anything over 75 and the Connie starts to drink fuel heavily no matter what flash it's running including ECO. If your going to average over 75 don't bother with ECO since their is no gain in MPG.
connie_rider
Zarticus; Do you recall if ECO Mileage improved after you added the various Flash's?
ie; If so, it indicates that the Flashed numbers are being used/adjusted.
zarticus
ECO Mpg stayed the same no matter what flash I had . Mpg changed on the flash map's but NEVER on the ECO map
kzz1king
That's my problem!
connie_rider
Also sed;
So, does that mean you no longer need ECO, as the flash you have gets better mileage?
zarticus
Also sed;
ECO still get's better overall MPG over ANY flash that i've had. So YES I do STILL use ECO, All Steve's flashes got better MPG than the factory REGULAR map.
Steve in sunny Fla
Iron Butt
Industry Vendor
Well, it's been fun but I know y'all are wondering, soooo.... I don't make changes to the ECO maps. For all intentions, ECO is still stock.
During my building / testing it was 1) enough work to perfect the full power map; and 2)my intent was to get full power very close to ECO in fuel economy, so there was no need for redundancy.
I think most folks can tell a marked difference in the full power map, pre and post flash. If you can't, or if you think it's the same as ECO... then I have to say to refer to the dyno charts.
Over the years I've flipped back and forth on steady state cruising to see if there was a significant difference. ECO would usually be 1.5 to 2 mpg better. I can deal with that. In fact the fuel economy on the 08/09's that don't have an ECO map will generally improve by 12 to 15% with the flash, and that's significant.
On the 2015 up, the fuel maps on full and ECO are exactly the same. Yes. Remember, fueling is being trimmed by the 02 sensors. On the 10 to 14, the map is leaner until the higher throttle openings. where it becomes the same. BTW... currently my 2015 up flashes (other than Hammer) enable 02 sensor monitoring, so I doubt there's any advantage between ECO and my flash.
ECO also has it's own independent mapping otherwise... if you notice the power difference that's really because of the severely retarded secondary throttle opening. Remember that if the fueling is leaner and the timing is advanced (it is) then sudden, hard throttle openings can build cylinder pressure to the point that the lean mix can't resist detonation. So slowing the throttle opening helps control those spikes. And remember, you're flipping to this map "to ride in an economic manner" .
Steve
fartymarty
SC AAD
So Ted, assuming we were talking '10-'14 since mine is a '10 and your ol' red thang is a '14....did I win a sip o yor pallet wood aged 'shine? :D
connie_rider
Ya could have a sip, but I don't have any.
My Kuzin isn't currently available to make any.
But, I'll let ya have a bottle of TeXaS finest Beer. (Shiner Bock)
Pr356
"In fact the fuel economy on the 08/09's that don't have an ECO map will generally improve by 12 to 15% with the flash, and that's significant."
Oh crud, ever since this thread was started I've been out in the garage looking for my ECU button on my neutron silver (faster than '14 red) 2008. 不不不不不 jk
On the serious side, my 2008 has always been flashed since I've owned it and the mpg has never been good (mid thirties) Might also explain why I go through tires so fast.
zarticus
It's almost as if you had some inside information! 不
Steve
To be honest I never new anything about the ECO map other than it NEVER changed no matter what Flash I had. That alone told me it was a seperate map all together. Also if the ECO was going to change at all you would of mentioned it on your website so buyers would know about it.
Steve in sunny Fla
Iron Butt
Industry Vendor
Very Astute. I assume(d) we has talked about it at some point in development.
Steve
waynesworld194303
Big Wheel
Forum Subscriber
Steve
Steve, I have a 2009 Connie. I would like to get it Tuned. But I have a couple of questions could you send me a message With your number so we could text?
fartymarty
SC AAD
Now wouldn't that be something?
ECO button that doesn't do anything!
Already brainstorming to see what farkle I can tie that into...
  • MISSILE LAUNCH
  • LEO CHAFF
  • OIL SLICK
  • MACHINE GUN
  • TED-B-GONE
I just now reread this thread and I can't believe that I missed that 5th option on the first reading. :LOL: :ROFLMAO:
Good one Harry.
connie_rider
You don't need a button for TED-B-GONE. It's automatic.
ie; When we do a Roll-on, (with Harry on the Green Thing and Ted on Red)
Ted
"will" be gone.. (far, far, "FAR" ahead of you)
