2016 Ducati Hyperstrada 939
cuda
What's not to like, I'm in LOVE
It's 460 lbs wet
$8,000
  • ABS
  • DTC – Ducati Traction Control
  • Riding Modes (Sport, Touring, Urban)
  • Ride-by-Wire system
  • Ready for anti-theft system
  • Heated grips
  • Sat-nav
Specifications​
ENGINE
Engine (type)Liquid-cooled, 4-stroke
Cylinder arrangementTwin-cylinder, 90° L-type
Bore & Stroke94,0 x 67,5 mm
Displacement936,9 cm³ (57,2 cu. in)
Compression ratio12.6+/-0,5:1
Valve trainBelt driven desmodromic DOHC, 4 valves per cylinder
Max. power113,0 hp (83,1 kW) / 9000 rpm
Max. torque97,9 Nm (10,0 kgm) / 7500 rpm
Acceleration 0 to 100 km/h (0-60 mph)3,2 sec.1
Top speed235 km/h (146 mph)2
Fuel system (type)MARELLI indirect electronic injection
Fuel economy / consumption5,2 l / 100 km (45 mpg)3
DRIVE TRAIN
ClutchWet, multi-plate, cable operated
Self-servo and slipper mechanism
Transmission6-speed
Final driveChain
Gear ratio
I
II
III
IV
V
VI
2.466
1.765
1.400
1.182
1.043
0.958
FRAME
Frame (type)Steel tube trellis frame
Die-cast aluminum rear subframe
Front suspension, travel43 mm inverted telescopic fork, 170 mm / 6,7 in
48 mm inverted telescopic fork Öhlins (fully adjustable), 185 mm / 7,3 in – Ducati Hypermotard 939 SP
Rear suspension, travelSwingarm with mono-shock Sachs (adjustable spring pre-load & rebound damping), 150 mm / 5,9 in
Swingarm with mono-shock Öhlins (fully adjustable), 175 mm / 6,9 in – Ducati Hypermotard 939 SP
Front tire size120/70-ZR17
Rear tire size180/55-ZR17
Front brakeDouble disc, 320 mm, 4-piston radial calipers Brembo monobloc (ABS)
Rear brakeSingle disc, 245 mm, 2-piston caliper (ABS)
Fuel capacity16,0 l / 4,22 US gal. (reserve – 4,0 l)
ELECTRICAL
Ignition systemInductive electronic ignition
Alternator12V-460W
Battery12V-10Ah
DIMENSIONS
Overall length2120 mm / 83,5 in
2130 mm / 83,8 in – Ducati Hypermotard 939 SP
Overall width895 mm / 35,2 in
Overall height1155 mm / 45,5 in
1225 mm / 48,2 in – Ducati Hypermotard 939 SP
Seat height870 mm / 34,2 in
890 mm / 35,0 in – Ducati Hypermotard 939 SP
Wheelbase1493 mm / 58,8 in
1498 mm / 59,0 in – Ducati Hypermotard 939 SP
Ground clearance181 mm / 7,1 in
203 mm / 8,0 in – Ducati Hypermotard 939 SP
Dry weight181 kg / 399 lbs (without fluids and battery)
178 kg / 392 lbs (without fluids and battery) – Ducati Hypermotard 939 SP
Curb (wet) weight204 kg / 450 lbs
201 kg / 443 lbs – Ducati Hypermotard 939 SP
Images​
