78k valve check.
kzz1king
Mine didn't move much second round. My first check I had 3 tight valves (40k) that I had to put smaller shims in to get a measurement. This time they didn't move much. Gonna leave them. Numbers with a .5 we're ones where the next gauge up went in tightly.
2andblue
Did you own the machine from showroom 0 miles? Seems like minimal movement, dissimilar to the average experience.
Also do you have the actual full measurement in inches or mm? Stinks to tear her all down for no opportunity to approve, but got to check...
kzz1king
No. I bought it at 30k. Adjusted at 38. At that time 3 we're way out of spec and the a couple more a little out. The numbers are just feeler gauges in thousandths., .009 and so fourth I could move some up to the higher end or middle but I am not sure that's needed.
Bagger John
My '08 will be coming up for its second inspection in a year or so. Will be interesting to see how much (if any) they moved. FWIW, I set all to the middle of their respective ranges when I had the bike apart for its first check.
kzz1king
That was my goal the first time but I didn't do the math quite right and didn't want to pull the cams again..I was happy to see mine didn't move much especially since so many were out of whack the first go round.
