on my 2013 I have noticed something hinky over the last several thousand miles. The last couple of days it is worse.
Trouble starting started months and hundreds of miles ago.
-charging normally while riding but varies ....has always shown 14.4 V on the dash. It began varying from 13.7 while sitting at a light to 14.6 when decel or accelerating
-Sluggish starts in the AM over the last couple of thousand miles
-recent stops for drink or gas results in really hard starts with KAct light staying on or Immobilizer Error flashing on dash
-This morning after 155 miles last night it turned over but did not start with a weak battery
Battery is the 2nd one installed in the last 1500 miles. This one is a couple months old.
Big gets ridden 5 days a week. Tody needed the jump starter
This has been getting progressively worse over time and was the same with the Fuzeblock and accessory lights and radar detector disconnected from the Battery or with it on. Noted slow crank and weak Batt symptoms over the last 8 months.
Kept on a Battery Tender at night and does not seem to matter whether it is connected or not.
I can't figure it out. New Batt, Fuzeblock connected or disconnected, Battery Tender on. All the same. Are these things weird about rectifiers or charging?
Cleaned and checked all grounds. Looked for any loose wiring or potential drains.....
Any Ideas? 94K miles. Engine pulls strong. Valves done most recently at 75 K . Runs like a champ....just does not instill confidence in starting.
