So I’m finishing up my fork rebuild and update. Installed all new OEM parts, RaceTech Gold emulators with yellow springs, drilled additional compression holes. All per Racetech instructions.
At the final point of setting the fork spring preload. Custom set up sheet for a 0.92 kg/mm spring would require a 25mm fork spring preload. This would be an almost 1” spacer ?
Reading thru instructions show to place spring, washer, spacer tube, washers and cap together with tube fully extended.
Measuring from top of tube to lip of fork cap and this gives me 161.9 mm.
Tried tech support but was on hold for 20 minutes listening to Bugs Bunny Muzak
Thought I’d try here.
First time doing suspension work and may just be overthinking it.
Thanx
Thanx
