I’m looking for a right side mid fairing panel for a 1999. Don’t know if the year matters. Just need a good mid fairing panel to get this thing on the road. Thanks!
I’m definitely going to try that, Bud! But for the winter time.. I’ve never rode a full faired bike and my naked Buell is a bit brutal below 40*. (Sure didn’t seem that bad 20 years ago!)
If you don't mind the work, pull all the inner heat shields, plug a couple of fairing holes and the heater will be on high. Best cold weather bike ever. Search on eBay and save the search so everytime one is listed, you're going to be notified. Found some hard to find stuff that way. Also look for the guy that wants to strip one down and do a bobber or something and has a pile in the garage that pisses off the wife. There's hot deals at that house! Best of luck
