Bob_C_CT said:As Bud stated, new spark plug well gaskets for sure. A slow leak there isn't good to find out while out on the road. I had to use a new cam cover gasket on my first valve adjustment because it had some cracks in it (it was probably the original) but the last time it was good to re-use. I have a spare I keep on hand just in case.
Just use the starter to bump it, don't use manual's instructions to turn it over with the nut under the side cover.
Mettler1 said:Get my gaskets from Murphs' !! They ship FAST!!
Bob_C_CT said:No need to remove pulse cover, bump engine with starter or as others have done put tranny in 6 th gear and then use rear tire to move motor.
The crankshaft nut under the pulse cover is pinned and if you don't have all the spark plugs out you will possibly break pin and end up with a bigger job. And one less gasket to have on hand.
WillyP said:Works for me too. Maybe our neutral lockout is broken?
JPD said:All of the Kawasaki bikes I have owned I have been able to up shift from neutral to high gear with the bike stopped. The PNF makes it so you don't bypass neutral from first when you are stopped. You will go from first to second when in motion. Once you are in neutral you will shift one gear for each movement of the lever. You will have to rock the bike fwd and back on the wheels or rotate the rear wheel on the center stand if the gear teeth hit point to point on the next gear. If they are lined up point to valley it will go right in. Just don't force it. I like the idea of doing it by hand with the bike on the center stand.
DO NOT RUN THE BIKE IN GEAR ON THE CENTER STAND.
As you go up in gears the wheel will be flying and any imbalance will cause it to bounce. Just shutting it off at speed could cause it to come off the center stand.
Jim said:It's not a matter of speed. Just roll the wheel slowly forward while pulling up on the shift lever.
Jim said:Neutral to 2nd, roll tire slowly and pull up on shift lever. 2nd to 3rd, roll tire forward until it bumps from taking up all the drive-line slack. Not too hard, just a good bump and pull up on the shift lever again. Repeat....
Bergmen said:Jim said:Neutral to 2nd, roll tire slowly and pull up on shift lever. 2nd to 3rd, roll tire forward until it bumps from taking up all the drive-line slack. Not too hard, just a good bump and pull up on the shift lever again. Repeat....
Yes, this can be done. I didn't believe it myself until Ken **** showed me how to do it. Not once but many times. It is just a matter of technique. But that didn't keep me from removing the pesky automatic neutral finder when I had the transmission out for another project:
With perfect results I might add.
Dan
MAN OF BLUES said:Interesting D
I'm a bit surprised.... but not amazed, :great:
Thanks for showing that pic also...
I don't call "ball" feature a neutral "finder" tho, I call it an "upshift lockout" mechanism...
Now for the million dollar question....
Can anyone explain why it exists, and why it has been a part of every Kaw tranny since the early 70' s, or even before?
Tjnoma99 said:I'm going to attempt my first valve adjustment this weekend. A few questions. Other than a head gasket, what other gaskets should I replace while I'm in there? I saw a reed valve block of kit from Murph. Is it worth it to do?
The Link contained herein is no longer working. Error 404You can do the valve adjustment without removing the pickup coil cover so you won't need that gasket. Just use the timing marks on the cams or have the lobes pointing up. With the plugs out, you can spin the engine with the trans in 6th using the rear wheel or just bump the starter. If you haven't found it already in the Tech Pages, here's the link for valve adjustment:
http://www.cog-online.org/clubportal/clubstatic.cfm?clubID=1328&pubmenuoptID=29654
When putting it back together, be gentle on the valve cover bolts: 87 in/lb
I concur with your signature line 1000%. Ad sponsors will pay you quite enough to keep the site FREE for all with the minor inconvenience of having to close an ad tag. No big deal to me. I host a different brand site and I charge NO ONE, yet, members feel the need to DONATE for all the wisdom and helpful members posts. I do accept Donation there, but I do NOT solicit them. I actually try and dissuade them. Some folks INSIST. Well if you INSIST.I've done two valve jobs now, and the second one was way easier with some experience.
I would highly suggest going ahead and replacing the t-stat, oring, and rear coolant long rings while you're in there. Not only is it good preventive maintenance, getting the cover back on is a breeze.
I use indian head on the cover side. Apply, wait a bit to let it cure, then put the gasket on and let it sit 24 hours. If you have the tstat and coolant log off, you can approach from behind. Like many have said, just a little RTV in the half moon wells, and a little on the corners. I went sparingly on that part as well. First attempt at mounting the cover was successful. Much better than the 3 times it took on my 06 to get a good seal without a leak. I hadn't taken the tstat off on that guy, so it's not a surprise.
