Fossilrider
Tricycle
Hey guys,Steve here.Well,for those who didn't see my comments about the front tire air pressure sensor,I got that taken care of but while he had the front wheel off he noticed some discoloration on a rotor so I looked at it and told him to go ahead and reassemble everything. When he finished,he test rode the bike and came back and asked me if the front brake lever had been pulling in almost to the bar.I replied that it hadn't and I had been thrilled with the brakes.At that time,the shop owner told me there had been some issues with the front rotors on the early C14s and they had replaced several.When I started to leave and got to the street I reached for the brakes and the front brake lever came almost to the grip! I almost ran out into traffic,but pumped it quickly and got stopped.I know that when you've had the wheel off and get space between the pistons and rotor,you have to pump it a few times to get the piston back out where it should be and I knew he had ridden it in the lot so that shouldn't have happened.I realize I should have gone right back in and addressed the problem right then but headed on home thinking whatever was causing this would get better,or I would check it out at home.(I know,STUPID!).It never really got better.The brakes were fine when I rolled the bike into their shop.Correct me if I'm wrong here,but I believe the mechanic (I'm useing the term loosly) had to have bent one of the rotors and it is pushing the piston back in its bore.Something else I didn't understand,he removed a rotor to dismount/remount the tire while replacing the pressure sensor.Has anyone here ever heard of that?I haven't.I am now waiting for new rotors that I am going to have installed on the front and am really uncomfortable with this mechanic doing the work.Oh,yes,one more thing that I didn't feel was kosher:he really leaned on the rotor bolts with an air impact when he reinstalled it.I'm really confused,and pissed about this whole episode.Any ideas?Regards,Steve
