2006 Stock Handlebars Low vs High specs
bzim7506532
I have a 2006 Connie but I am trying to figure out if I have the low type or the high type. The drawings don't have dimensions and I am having trouble comparing because I don't see any obvious tell-tale sign. Does anyone have any dimensions of what they have and whether it is the low or high version?
I would doubt that an 06 has the low version unless someone changed from the stock bars. I believe the low versions came on the 86. I'll go measure in a bit. Posting a pic could be helpful without measurements.
On a 2006 you will have the higher handlebars. The lower bars are pretty rare and it's pretty doubtful that anyone would have installed them on an 06..
I "thimk" the low Bars came only on the 86 and 87.
The stock clip-ons on my 2002 are approximately 6" from bottom flange to the top, so a bit over 5" rise to the center of the handlebar.
My understanding is that 1986 was the only year for the "low" ones, which were about 1" shorter.
