my 95 connie has developed a loose valve noise when idling but goes away as i pull in the clutch. i seem to remember there being a clutch problem on some models.any ideas
Chris, The noise you hear is not related to your valves. The clutch basket is supported by a large bushing running in oil. There is a very small amount of play, and it will either rettle or growl a little bit at idle but goes away with some throttle (just going off-idle) or pulling in the clutch. It's normal and no cause for alarm. The only problem I know of is when the star spring breaks, which mine did after a day at a racetrack and heavy downshifting. I guess it happens with normal use too but I am not sure how often it occurs. David David in Jax COG# 7898 NE FL AAD & COG Vendor www.dreamjobresumes.com preparing resumes for COG members and friends I ride a KAWASAKI ZZR1200 - Euro http://www.motorbikestoday.com/reviews/Articles/ZZR1200.htm US http://www.motorcyclistonline.com/roadtests/2002_kawasaki_zzr1200/index.html
