I want to ad charging port for my phone/gps. Problem is, I have no idea where to pull power from for this project. Also, if anyone knows where I can get one I would appreciate any help.
Thanks
Thanks
A switch wouldn't be too difficult to add with whatever wire harness you fabricate. Initially, I just used a cigarette lighter socket, routed the wires through the drain hole in the pocket and used crimp on male bullet terminals to tap into the accessory terminals. You're looking for wires with the female connectors. The black and yellow is ground. I think the positive is white and blue? I never had any switch, I just pulled out the USB charger between rides. Later on, I installed an additional fuse block and wiring that could power more accessories. That was rigged with a relay to only power up with the engine running.Thank you!
Is it possible to ad a switch in the line?
I did the same thing. I use the rear brake light switch for my trigger. There is a bullet connector just above the switch and I made a "Y" connector to put inline. No cutting/ splicing wires. GPS, aux lights, Cig lighter or muti usb power port, all turn off with the bike. During shutdown you can select the GPS so stay on with its battery.I'd start by adding an auxiliary fuse panel, cuz once u start adding electrical farkles you won't stop...lol. next itll be aux lights, louder horn...like Jorge did
