I did this on the '06 Nomad 1600 I had prior to the Connie.The main issue looks to be the Connie windshield is more curved so you might have small edge gaps. And, of course, cutting a hole in your windshield... If I had a pre-'15 I would probably do this.
If your serious about more air watch the short movie, as these are tried and tested over the years. These are still available. Snap Vents, relatively inexpensive.
