BeamTech LED Head Light install - Is this Correct?
dsamudio
Just want to make sure this looks correct for the LED head light replacement.
Would like to hear from other Texas riders or riders that have this install and ride all day in the heat.
Thanks all,
Dimitrius
Something doesn't look right. Which Beamtech did you install?
If you're using the same Beamtech I used...
:::: Mine; https://www.amazon.com/dp/B06XHD78DQ?ref=ppx_pop_mob_ap_share
If same as mine, Installed as you have it, the heat sinks can't radiate heat.
You are supposed to remove the black plastic locking ring from the LED Bulb (it twists to unlock), install the ring on the headlight, install the rubber seal, and then install the LED bulb thru the seal. (it twists to lock)
1) The ring is easily removable.
2) Install the LED Bulb with the correct side up. (When shined on a wall there should be a flat/dark area at the top)
That did it!!
I had:
Installed the Black Plastic lock ring
Slid the light through Dust Cover
Then installed the Light and cover as one unit.
This distorted the dust cover.
All good now.
Thanks Connie_Rider
Dimitrius
