Howdy,
Clutch fluid is looking pretty dirty. I have the OEM manual and went through the "procedure" with the two bleed screws. Also did a search of this site. Since this is the first time that I have had to bleed a hydraulic system with a bleed valve on the master cylinder I was wondering if I can still just use my Mity Vac and suck the fluid through until it comes out clean at the slave cylinder bleed valve ignoring the bleed valve on the master cylinder?
Thanks,
Norm
Thanks,
Norm
