I'm working on developing Brackets to install 4 Pot Tokico Brake Calipers on my 2003 Connie.
If I succeed in the project, I could build additional brackets.
My question is: would anyone be interested if I made extra Brackets?
I talked with 2 fast and others that have built brackets and installed newer calipers. "All" feel the braking is far better than stock.
Background:
The Calipers I purchased came off of a ZZR 1200. (Cost me $60)
The same calipers can be purchased off of multiple Motorcycles, including some GSXR's ZZR's, ZX's, ond possibly some Hondas?
I will (eventually) compile a complete list of calipers that will fit the new brackets...
I'm building my brackets to work with stock (300 MM) Rotors. (95 and newer C-10's)
This will give me better braking without the additinal cost of purchasing 320 MM Rotors.
I talked to others that have added the 4 pot calipers and they suggested that I use stock 300 MM Rotors.
They admit that the 320 MM Rotors are slightly better than 30 MM Rotors, but the biggest improvement was the caliper instalation, not the addition of 320 rotors.
And, (Most importantly) using 300 MM Rotors saves about $100-$300 on the project.
My brackets are a bit different than others I've seen on the Forums.
They will be made of Alumium instead of steel.
I will build 4 lighter/aluminum brackets rather than the standard 2 steel brackets.
Brackets will be anodized (probably blue or gold anodize).
To ensure the bolt threads in the aluminum brackets, I will use steel thread inserts.
Calipers will not require Mill work to fit the brackets.
I do NOT have a final cost for the brackets, as the cost of building them is dependant on how many I have Machined and Anodized..
My best guess is $75 - $100 per Connie.
Total project cost for someone to install the (Tokico) Calipers on their Connie would be the cost of the brackets and the cost of the Used calipers they buy elsewhere...
Brackets will include the bolts to do the installation.
Should be a Bolt-On Project.....
Is anyone interested?? :confuse:
Background:
