just installed flasher unit, a30 min. job. very quick on and off, like a burst, for about 2 sec. then steady on. all kinds of adjustments, set it up how you like but it sure gets your attention when you put on the binders
Wayne, I looked at those type too but I have a Coocase trunk, I enlarged those brake lights and the flasher flasher does the bike and trunk. 3 lights. See you at Lake George, black ,09 with Red seat. ALSO WAYNE
