I've a Cee Bailey with a vent and have not noticed any significant water intrusion through the vent. I've had the unfortunate opportunity to ride through several pretty hard rain storms (and hail) so it's been "tested". YMMV, depending on the height of the windscreen.
Another attribute of the vent is to equalize the airflow to create a more stable pocket of air for the rider. The vent is adjustable for closed or open positions during riding. In hot weather, it allows airflow into the cockpit as well. I would spend the extra $$ and get the vent, or else you will always be wondering what it would have been.
The Cee Bailey vent is not adjustable. You are probably thinking of the Clearview. It has a vent like the Goldwing. Eddie 2005 Concours 1969 Triumph Bonneville AMA# 686667 COG# 7073 CDA# 0136 http://picasaweb.google.com/Eddie753
IMO CeeBaily with vent lets lots of rain in. I run most the winter with mine plugged. I dont even bother to remove it on nice days. In summer the plug is in or out as needed. http://www.fredandrose.com/Concours/images/Dscn3042.jpg
I agree with Slybones. I use the foam tube you use to insulate pipes in the winter. It pops right in and out. However, I have not noticed that much of a problem with rain. I use my plug mainly for the cold in the winter as if there is no ice I ride. I would not have one without the vent. Respectfully Yours! Wess Heavner COG #8010 CDA #0239
Mine is 23 1/2" with vent, and the wind buffeting is greatly diminished, however I don't know if it is due to the vent or less curvature of the lip. As far as rain protection goes, in heavy rain I plug the vent due to water funneling through.
