My 98 Concours is having some difficulty. We took off for a ride two weeks ago and I was having trouble shifting, like the clutch was not engaging, we turned around and the next week I changed the fluid and bled the clutch slave till I had pressure again. With the bike on the center stand I started it and put it in first gear, tire spun with clutch engaged, releasing clutch killed the bike. I then drained oil and remove the clutch cover, engaged the clutch lever and only the front plate moved so I removed all the plates and cleaned them thinking it has sat for awhile and the plates were stuck together. I then replaced the plates,engaged the clutch all plates moved and after waiting for 6 days to get gasket I put the clutch cover on. I filled it with oil and tried again same result.Anybody have any ideas what to try next, I can't afford to take it to the stealer for repair, so I need to do it myself just not sure where to start. While writing this post I had a duh moment and realized it dies because I left the sidestand down, with sidestand up it stays running, but still spins when in gear with clutch engaged. I know this is a long post, but I wanted to explain what I have tried. Thanks in advance for any helpful suggestions.
