I got my 2009 Connie Father's day of this year and immediately noticed that upon start-up when I went to put the bike in 1st gear that it immediately started to pull forward even though I had the clutch lever in all the way. Was wondering if this is normal for the Connie's hydraulic clutch. I usually park the bike leaving it in first gear (how we motorcops are trained to) and have also noticed that it was a little stiff to move manually when off by squeezing in the clutch lever. I've further noticed that after the bike has warmed up, the pull is not as bad. Comming off of a 1999 BMW R1100RT-P , I am not used to this and wanted to make sure it is normal. Was also wondering if there is any way to adjust the clutch even though the manual says it don't need it 'cause its hydraulic.
Thanks all,
Andy
Thanks all,
Andy
