JJPSUPERDAD
Training Wheels
OKAY which oil filters can we use with out trouble ? is it only the stock filter? >
joe in calif said:I have never used anything but OEM filters on a any of bikes, can't see saving a couple of dollars on something as important as an oil filter. Guys on the Gold Wing site will spend $25,000 on a bike and want to save $4.00 on a filter, I don't get it, I bought my Gold Wing filters 10 at a time and got them, for $8.00 each.
Teleskier said:I have hated oil threads on motorcycle sites for years and I have a feeling this is going to be another one. I cannot believe all of you who insist an OEM filter is superior in filtration and protection to certain high performance filters. What are you basing your claims on? What research have you done? Is it just that you think Maw Kaw will honor your warranty with one and won't without it? I call crap on that one.
So just what is it you are looking at? Element material, amount of filter material surface area, size of material filtered in microns, percent effectiveness, anti drain back valve material and shape, case thickness?
If you look at the hard data on all of these things I am pretty sure you will find that Purolator is 99.2% effective down to 20 microns while your OEM filter is only 85.2% effective down to 20 microns or about 10x more material is getting back into your engine with the OEM. You will find similar protection with the Mobil 1.
I too think Purolator is full of crap when they say not to use the the PL14610 on a bike. The ML filter they suggest and the one I listed the part number for earlier is made in China and branded with their label. Would you trust that on your bike? Myself and many many others have used the PL14610 for years and probably hundreds of thousands of miles between us with no problems. I did not have the exact part number in front of me when I made that post, hence it was incorrect. I do not and will not use the ML filter, only the PL14610 or a Mobil 1 M1-110.
Feel free to contact the filter companies and talk to a few oil company engineers as I have and form your own opinions. Lets face it, if we change our oil at frequent intervals and use a good filter the motor will probably outlast us. But there are better filters out there than OEM for the same or less money if you shop around so why not use one.
Just my .02
Bergmen said:"What About PureONE
If you're thinking you want to install a PureONE oil filter on your bike, please think again. PureONE oil filters are designed for vehicles, not bikes. Because of PureONE's high efficiency, the motorcycle oil pump may not be able to handle the pressure. The Purolator motorcycle filter line is designed to meet the specific needs of a bike; therefore we highly recommend the use of a Purolator ML filter over a PureONE oil filter."
You can ignore their specific advice if you want to. I tend to follow it.
Dan
yes i love the K&N http://www.amazon.com/KN-303-Motorcycle-Powersports-Performance-Filter/dp/B000E2CVIStrailer_parks said:After fighting with my filter (with appropriate wrench), I'm on board with any filter that has a nut welded to it. Only a K&N feature?
joe in calif said:Once you get the factory filter than the one you put back on shouldn't be a bear top take off it you don't over tighten it. One thing about after market filters that FIT a different vehicle, the filters have a pressure valve in them, if the pressure valve is not the same as the OEM you can cause damage to your motor.
Read this
http://www.peterverdonedesigns.com/oilfiltertest.htm
gasman5.0 said:The Purolator PL14610.....Yea I know my bike is a tick'in time bomb with the unapproved "car" filter :deadhorse: ?? Any oil opinions guy's ??? :deadhorse:
Cap'n Bob said:It actually costs more for me to use OEM or anything other filter from the dealer. I don't know about y'all. But my closest dealer (where I tend to support) is 20+ miles each way. I figure that it probably costs me $15 or more in fuel for my truck to run out there. Although if I take one of the bikes, it's about $5 in fuel. So when I go to the dealer. I try to go combined with some other trip.
Teleskier said:parts guy,
Everything you stated is true and valid and compares to all of the research I have ever done into oil filters.
