Good used Corbin Seat, does show some wear and tear some stitching is missing but seat works as intended. Asking $325+ shipping
Cant figure out adding pic with new format, but you can message me with email or text and I will gladly send pics.
Use the Insert link button in the menu banner above a new message to attach pics. It looks like a chain link, it's nine icons over from the left. You can also use the mouse to hover the icons to determine which is the correct one.
So you can upload this way as well:
Imgbb.com
Start Uploading
Select photos
Upload
Select fullbb code
Copy code
Paste in your post here
Delete everything before [ img] and after [ /img]
This works better on the new forum since it doesn’t compress the image side to side.
