All,
Last three rear tires have been cupped real bad. One Michelin Pilot GT & two Avon Azaros. Bike (2002 C10) now has 91k on it, new rear bearings, swing arm is torqued to spec, tires were mounted & balanced by a local private shop. Front end has fork brace, Sonic 1.1 w/15 weight oil, fork preloads at first line. There is no noticeable wobble/play on the front or rear tires when they are off the ground. Front steering seems to be fine, no clunking. Keep the rear tire at 42psi and front at 40psi.
On the list to do is to replace the oil in the rear shock, new swing arm bearings and replace the bushing on the top of the rear shock. Question, do the needle bearings on the linkage wear out or need any type of maintenance?
Also, I've been fighting a sway (ball bearing dance) when the bike is in dirty air (like around semis, suvs, strong wind, etc), thinking the rear tire cupping is related.
So, anyone have thoughts on what is causing it? Or have past experience with rear tires cupping?
Kurt
Kurt
