Has anyone used one of these ? My main concern is if it has a BMS onboard, and for the price it should. However, no specs that I can find show much technical detail about it.
It has to have a battery manager on board, as it has a built in state of charge indicator. Cycle Gear customer service is excellent and I would have no worries about getting the battery from them.
well after running around all day finally locating the battery at Cycle Gear, I ended up returning it! Little detail their guy missed, and so did I, was the "L" at the end of the part number, meaning the terminals were reversed. I was not happy after wasting a day. But returning for a $203 refund and finding I could get the NOCO-14 for 70% of that price from the AutoZone down the street, well, I went and ordered it. I've used NOCO products for years, even showing, to the amazement of people around, that my handheld battery booster would jumpstart my freightliner tractor.
They have been around lithium batteries for a long time now and I feel confident in their products.
I wish Cycle Gear would have provided more technical information on the battery. I have Lithium iron phosphate batteries for powering radio equipment and they do NOT have any type of BMS, so I was not sure if the Duraboost had one or not. It is a selling point, and cheap Li batteries marketed for bikes do not have one.
What is the advantage of Lithium Batteries over AGM batteries?
Do they last longer? CCA is far higher? Lighter? What??
Update; I looked back at a discussion I started about installing a size 16 AGM battery in our bikes.
NOTE: I installed a Yuasa in mine at that time and it's doing fine. Nov. 2019
Later others discovered the Motobatt battery it has 4 terminals instead of 2..
Motobatt Quadflex batteries , the first and unique 4 terminal system, proposes the best balance between CCA and Amp hour capacity. Due to utilizing the wasted space inside a standard battery case, Motobatt maximizes the dimensions of the plates internally. Additionally the plate grids are made...
www.motobatt.us
So, getting back to my question. What is the advantage of the Lithium over these?
I have been running EarthX Lithium Iron Phosphate batteries for 9 years now on my 2011 C-14. The first battery lasted 8 years with zero problems. While the initial cost is higher, I see the these advantages. Smaller, much lighter, center mounted terminals, battery management that shuts the battery off if you leave the lights on for instance. They can use something like 90% of their energy before the BMS shuts it off. The BMS can be reset and the bike will start. They hold their charge while in storage, have a considerably longer lifespan and a greater cold cranking amp rating for their smaller size. They charge considerably faster. They don’t catch on fire and yes they work in the cold. When I finally decided to replace my EarthX battery it had zero corrosion after 8 seasons of riding. I’m sure I’m missing some other things, but I can share they worked great for me. The EarthX will be the next battery on my 2019 Versys. I can’t speak for other brands.
I looked up both of my orders and used the EarthX ETX24C Lithium Iron Phosphate battery both times. No issues with room to spare (they supply rubber pads to fill in the extra space if needed) and with the way the posts are set up, the cabling is easier than the OEM. You shouldn’t go wrong with their fit guide. They answer the phone for questions, and I believe are based in Colorado. A bunch of places sell them, including Amazon.
I’m guessing cost the first time and then got the same again. More Cca and Ah if it fits is best and the models you listed are newer. I’m sure the one I bought exceeded the OEM. A purist will tell you to use the Optimate charger. I believe the battery management system allows any charger to be used without desulfation.
