You can get rid of the warning each time you ride by resetting the dash. But every time you turn the key off and back on, it must be done again. Not the best way to go. But better than looking at the warning flash.
When mine started doing it it would go away after a period of time, it would return but then go away again on it's own, but as stated by cap-n'Bob push the button on the dash to reset it.
