Coggers,
I am always looking for a better way to remove and replace the 4MM bolts that hold much of the fairing pieces and the 5MM bolts that fasten what used to the glove box on top of the tank. Hex head wrenches are great but they are getting expensive for a nice set. IMO, these are easier to keep on the bike.
These little gunsmith mag drivers hold .25" bits of all kinds. So I use one with each of the sizes encountered on the plastic parts. For me it is good because they give you a good feel that you do not over tighten the bolts into their well nuts or other threaded receivers, they are just a tad over 4 5/8" long and work well with a #2 phillips to remove the brake reservoir covers without hitting the screen. They happen to be on sale at Grizzly.com for 23 cents each, if you can believe that. Shipping cost more than ten of them but the cost averaged out in my favor, IMO. I just put one of each size hex bit into a driver plus #2 phillips and I am good to go they fit in a small roll up or plastic bag.
www.grizzly.com
Just thought you would want to know...
Cheers!
Gilbysan, aka - Fat Ninja
Mag Tip Screwdriver for Tool Chest at Grizzly.com
Compact Magnetic Top Screwdriver accepts all hex bits for interchangeable screwdriving convenience. Magnetic top holds hex bit as well as fasteners for one-handed applications. Commonly available hex bits are not included.
Cheers!
