razorsedge
Scooter
Would someone please take the time to explain to me what FLASHING the ECU means and why you would remove the butterflies ? I don't get it. But also I come from the Harley world. lol
Trouble said:Would someone please take the time to explain to me what FLASHING the ECU means and why you would remove the butterflies ? I don't get it. But also I come from the Harley world. lol
KawiMick said:Trouble said:Would someone please take the time to explain to me what FLASHING the ECU means and why you would remove the butterflies ? I don't get it. But also I come from the Harley world. lol
Randy,
"flashing" is the process of changing the data on a ROM chip. Our ECU's are 'flashed' at the factory with certain fuel and engine control tables. If you want a more aggressive 'tune' you have to 'flash'.
The 'butterflies' being referred to are the secondary throttle plates that are upstream of the actual throttle plates you control with the throttle. These secondary plates can alter the amount of air that enters the engine. They are under control of the ECU.
Clear as mud?
Trouble said:what's the reasoning for the secondary butterflies ? does flashing your ECU cause warranty problems or void it ? And the BIG question, does any of this make that much of a change in the HP and Torue ? I mean really ! The freakin thing is a rocket already.
KawiMick said:Trouble said:what's the reasoning for the secondary butterflies ? does flashing your ECU cause warranty problems or void it ? And the BIG question, does any of this make that much of a change in the HP and Torue ? I mean really ! The freakin thing is a rocket already.
1. The ECU controls the engine output power with the secondary throttle plates. They are also used with the 2010+ traction control operation.
2. Warranty would only be affected if a failure could be directly related to the ECU tuning.
3. Yes, it makes a big difference in Torque and HP on my bike with a full Muzzy dual exhaust.
If you remove the butterflies, will it effect the traction control ?
Trouble said:If you remove the butterflies, will it effect the traction control ?
Trouble said:why you would remove the butterflies ? I don't get it. But also I come from the Harley world. lol
Fred_Harmon_TX said:=
So you can see through your windshield? Lemon pledge does a nice job loosening them up so you can wipe them off.
Stewart said:I had my 2010 bike flashed by Ghul Motors, plenty of info per Freds links. I like to think I can ride, but I'm no expert rider and still have plenty to learn and improve on.
The key reason I had the flash done was to gain the improved low end torque and to smooth out the power curve. Does it make the bike harder to ride?...absolutely not in my opinion!!
I think it makes the bike smoother especially in the twisties where you want low end torque and are using lower gears, I don't feel like I'm riding the bike as hard and it just gobbles up the corners.
The other question is is the throttle more twitchy? I don't think so, I can barely tell the difference until I'm giving it a solid twist.
Trouble said:Stewart said:I had my 2010 bike flashed by Ghul Motors, plenty of info per Freds links. I like to think I can ride, but I'm no expert rider and still have plenty to learn and improve on.
My problems not so much the power delivery, rather the freakin jerking of the drive shaft. I can let off thr throttle and it jerks bad. then back on throttle and it jerks. theres nothing smooth about the power flow in curves with the C14 for sure. I've tried everything. To be honest, Im shocked at how hard it does jerk . Don't know if thats normal for a shaft drive or not, but it's to the point its really strong deturant regarding the positive aspects of razor edge cornering. there's nothing smooth about it. Why is it like that ? Can't they tighten the shaft up ? Does it need that much play that it has to jerk like that ?
I think you should get a throttle tamer (G2) or modify your existing ramp at the throttle tube if your comfortable doing that sort of thing. That and keeping throttle cable slack to almost nil (revs should not increase as the handlebars are turned while stopped). As the miles pile on you will get more used to controlling a high torque/hp fuel injected engine, and the your ability to handle drive line lash through throttle control in the twisties will get better in time. I have the FJR, and that worked for me and I imagine the C14 is similar in this regard.Trouble said:Drive line lash ? Ok ! I was wondering what it was called. Ok, I tightened up the slack in the throttle. Still does it. I guess this is something I will have to get used to. it just don't feel healthy. Im afraid Im going to jerk something out of the dive line. but if this is normal, then it is. Im learning to adjust to it. All im saying is if you let off the throttle and back on in a curve and your around 5K or over, get ready for that lash back BIG TIME.
Jagman said:I also own a BMW K1600 GT and I suppose it could be used an example of what "driveline lash" is, for someone wanting to know what it is, but an understanding of the throttle and clutch all but eliminates it on the Bimmer.
