JohnC
Street Cruiser
Yesterday I parked RD (88 connie) in the garage as usual, all was working as it should. A little while ago I went out and was going to run some errands. I turned on the ignition, no oil light. OK, what goes here, switched the ignition back and forth, checked the kill switch, still the same. Made sure it was in neutral, hmmm, also no neutral light. Cranked it up and it ran same as usual, just no oil light, no neutral light, also no tachometer, gas tank was showing full (which I know it isn't,) and even after riding it for a bit, the temperature gauge still read cold. Turn signals work, brake lights work, headlight works, driving lights work, but the fog lights do not work. Now my sinking suspicion is the J box. Any other info you can add would be appreciated. tcars John
