Excess Electrical Capacity ???
2andblue
Little confused - Within the Owners Manual guidance for electrical accessories notes that no more than 60W of total load should be placed onto the vehicles electrical system otherwise battery could discharge even with engine running.
Looking at heated gear for my wife and I a single Hotwired 12V jacket liner pulls up to 74W, Gerbing 77W and First Gear 90W and pants are an additional ~38W.
My simpleton math tells me my wife alone with a jacket liner and pants liner (both at the lower consuming Hotwired brand clothing) more than doubles the capacity of the C14 electrical system.
What am I missing - this makes no sense to me especially considering I see/ hear of others running electrical clothing, the extra lighting and other farkles out there.
Thank You for the input.
Konehead34
Well, i for one dont run my farkles off the bikes accessory plugs. I run all.my farkles off a switched accessory fuse block thats connected to the battery.
Im certain one of the engineers here in Cog forum land will explain the watts (lol had to do it) and whys....
2andblue
That’s cool - but what is your overall draw? Does the draw exceed 60W?
Manual implied total draw of all external accessories should not exceed 60W - once over making me scratch my head as that’s not a whole lot...
rexter
Moped
Forum Subscriber
The alternator is supposed to put out 590w with about 350 usable for external accessories.
Scary Harry
Fear is not boring. COG# 4090
My manual says the alternator can put out 14V and 41.5A @5000 RPM. Total power is 581 Watts. Don't know what the bike draws for lamps and heated grips or anything else. You could put an Amp meter on the bike to find out.
2andblue
Rex, Harry and Konehead you got me thinking, pulled together a basic listing of electrical items. Some are swags..
Overall it does seem reasonable to expect at least 300 Watts consistently available for use and up to 350 Watts occasional depending on what is turned on e.g. Heated Grips...
ItemDraw (Wattage) X Qty = Total
Primary Headlights 55W X 2 = 110W
Central 'City Lights'5W X 2 = 10W
Tail Light25W X 1 = 25W (Total guess)
Turn Signals 21W X 2 (each side) = 42W Intermittent usage
License Plate5W X 1 = 5W
Heated Grips
30W X 2 (W based on comps) = 60W
Fuel Pump, Injectors, Sensors, Cluster, etc
100W Total SWAG
Total
352 Watts
Thanks for sharing the information.
Wayne
Scary Harry
Soooooo...about 229 watts to play with. More if you don't use blinkers, heated grips.
I'm gonna make a note of this in my owners manual.
2andblue
Other draw/ consumption that is not accounted for is recharging the battery. Above chart does not account for this.
Surprising how little extra wattage is available for a sport tourer designed for 2-up riding.. On the other hand, no cruise control either...
I Feel Fizzy
Interesting. I notice when I pull my 2018 Concours in the garage after riding and plug in the Battery Tender, it goes red for about a minute every time, before going back to the green 'float.' My 2001 FZ1 with 114,000 miles never does that - it is always green after a ride. Battery gauge on the Connie dash shows 14 volts all the time when riding, so I just figure it's the nature of the beast.
Scary Harry
What model Battery Tender?
Scary Harry
Battery Tender Junior.
I just read the manual.
A minute is not really long enough to charge anything.
My guess is that the microprocessor is evaluating the battery condition, and then determines that it will go into storage/float maintenance mode (low constant voltage, battery is 100% to 103% charged).
Are the batteries identical on both bikes?
Are both bikes drawing the same amount of current when parked?
Do both bikes have clocks or other farkles that can drain the battery at the same rate?
Are both batteries the same age?
Is there a low leakage path in a connector that is draining your battery faster than the other bike?
You could try swapping batteries and looking for any difference.
From the manual:
 RED LIGHT FLASHING – The red light flashing indicates that the battery charger has AC power available and that the microprocessor is functioning properly. If the red light continues to flash, then either the battery voltage is too low (less than 3 volts) or the output alligator clips or ring terminals are not connected correctly.
 RED LIGHT ON STEADY – Whenever the red light is on steady, a battery is connected properly and the charger is charging the battery. The red light will remain on until the charger completes the charging stage.
 GREEN LIGHT FLASHING –When the green light is flashing, the battery is greater than 80% charged and may be removed from the charger and used if necessary. Whenever possible, leave the battery on charge until the green light is solid.
 GREEN LIGHT ON STEADY –When the green light burns steady, the charge is complete and the battery can be returned to service if necessary. It can also stay connected to maintain the battery for an indefinite period of time
I Feel Fizzy
Wow, thanks for the detailed write up! The 2001 FZ1 is old school, when it's off, it's off. I just looked at the Battery Tender, and it is not the Junior, it's the regular Battery Tender - my bad. The 2018 Concours did it since I got it with 233 miles on it. Sometimes it does take a little longer than a minute - I was wondering if they all do that? Not really concerned about it, I just figured it was normal for that machine.
Scary Harry
I have the larger Battery Tender Plus.
Depending on the battery condition and leakage current (if any), My charger will go to red, then to green after a minute or so. So, it sounds like your charger is behaving properly.
1. Always, disconnect AC first before disconnecting battery leads, and
2. Connect battery leads first before plugging into AC.
It does make a difference as you could fry the Battery Tender.
I know cause I have done it. (May not be true with newer models)
Jpd11958
I have an old original battery tender. It came with white plastic connectors. It does the same as the OP. Goes red when first plugged in, then green after it has had a chance to determine that the battery is fully charged. The newer ones probably do that faster, better microprocessors.
big0red4224
Bicycle
Forum Subscriber
The short answer is they don't want you pulling more that 60 watts to make sure you don't cook a specific circuit. Wire your own circuit off of the battery, and you've got whatever your wire is sized for.
If you upgrade to LED headlights and city lights, your total wattage usage goes way down. My LED low beams use 40 watts together, the highs use 55 watts together, and the city lights 6 watts for the pair. That's 74 watts freed up with the low beams on.
C 14
Scooter
Forum Subscriber
Mine does the same, with the Battery Tender Jr. It is normal.
