If the heet comin offa yer Conc is an ish, here's a *reel* EZ tip. Next x ya got the plastique off, take a look at the black inner air dams on the sides of the engine: 14073-1276 DUCT,RADIATOR,RR,LH 14073-1284 DUCT,RADIATOR,RR,RH See the air space? That nasty heet's comin atcha rat thar! I got some heeter hose from the auto parts sto (a few bux), cut it lengthwise, & stuck it on the inside edges to plug up that air space. Add more layers if needed. Also make shure that the dam on top of the radiator is part of the scheme & is on rite. 14024-1267 COVER It's not a silver bullet, but it helps. 01 Conc, Mijami Floriduh Over the Pond 06: http://tinyurl.com/2vk9o2 route map: http://tinyurl.com/4p7pmd
