Ok. Got the minor leak from petcock bolt - one of the OEM plastic washers I was using bolt hole was deformed plus I had metal washers over them which according to schematic were not necessary. So two brand new washers and the leak is fixed. Tried to fix my fuel gauge sensor issue by bending forward metal tab the prevents rod with float from rotating too far into the tank. But doesnt seem to have fixed the issue. Will try the resistor fix next, I did this before I had to dry dock her and the shop must have removed it during rehab work. Got my lowering links and dropped them off at the shop. I'm gonna have them drop her 1.75". Any thoughts on this. The will lower the front too and bend the side stand. I'm gonna try the 2x8 in the garage to see if this helps get her up on the center stand, if too much of a problem they can adjust the center stand too. Next will try the Easy Power Mod and see if I can get the PO heated grips working.
