I put the replacement motor in my 2003 last spring, along with the Meanie conversion with 17" front, Sonic 1.1 w/ emulators, on and on. Almost 12,000 trouble-free miles later, I put on a new set of PR3's in preparation for my trip west, leaving on the 10th of May. This weekend was to be a shakedown trip to check everything out, including me.
The bike ran super, having adjusted the valves and synching the carbs. About 100 miles down the road, I stopped, and noticed oil on the rear rim. The final drive was leaking from between the spline and the wheel.
I got home this afternoon and pulled the wheel and final drive off as a unit, like I always do. It is indeed leaking from the seal in the ring gear cover, and I have a guess why.
When I cleaned up the splines for re-lubing with Moly 60, I used a spray bottle of clean parts cleaner (like used in the parts washer) and an old toothbrush to clean up the splines. I then did another perhaps foolish thing and blew it out with compressed air. I'm guessing I drove some grit into the seal and it failed.
That being said, I still need to get this fixed, or I won't be going anywhere on the 10th. I have the shop manual, and am a handy enough guy to tackle fixing it. Am I missing something, or can I change just the seal? Perhaps someone that has done this before will chime in with the easiest way to get this done.
HELP!
Cafefill
HELP!
Cafefill
