I recently changed the final drive oil and used pliers and a half dollar to get the filler cap off. Is there a better tool I can use? Please help!
Wreckin Ball
My local auto-zone sells a spark plug gap tool made of somehting that resembles soft brass. It happens to fit the cap perfectly. It fits tight, so no cap damage. I could not find a half dollar and five dimes did not help at all.
Murph's sells machined aluminum filler caps. I got 2: the same cap fits the crankcase oil fill and the rear drive. They come with a little pin-wrench. Nice!
