On page 19 of the Fall 2010 issue of the Concourier, I published a short article on how to better secure your saddlebags without drilling holes in them and pinning them. Due to popular demand, I'm going to share that fix here.
The basic problem is that there is slop in the interface between the orange latch arm and the mounting point on the bike that it engages. So my fix is to simply get rid of that slop by tightening up the interface. I simply cut a small strip of some adhesive backed felt (like you put on the bottom of furniture to protect a wood floor) and put on the inside edge of the orange latch arm where it engages the "hook" on the bike. I then cut a square of velcro (furry side) and put it over the "hook" on the bike. This takes up the slack between the hook and the orange latch and tightens up the entire mount. Alternatively, you could probably use a thick piece of hard rubber in the orange latch if you could glue it in so it would stay.
Tightening up the bag in this manner helps prevent the rear of it from being able to lift up and disengage the side hooks and come off the bike.
I've also put up a photo gallery here showing some more pictures.
http://www.pbase.com/fredharmon/baglatchfix
