I had just gotten home from a ride. Filled the tank about 40 miles out, so it had 6+gallons on board. The last couple of miles I was smelling a little gas. When I got home, I saw gas squirting out from under the tank just behind the petcock. And onto the engine and pipes. Pulled the tank off in a hurry, and drained it into a can. Do you know how long it takes 6+ gallons to drain through a 1/4" hose? So now I've got two holes along the inner tank seam, each about 3mm x 1mm. See pic at http://www.savvypaddler.com/Images/T_tankholes.jpg. Can these be patched? Lined? Good ideas welcomed. Thanks, Steve
