Thinking of installing the gpz900 head. Many have talked about how important intake velocity is. I’m wondering if the ports on the intake side are smaller and would help with intake velocity. Also think it may increase compression. Would also do a slight port and polish just match the exhaust ports as they all are not uniform and remove any casting imperfections on the intake and exhaust side. They make a 1000 head gasket for the gpz900 head and the mounting points appear the same. Not sure if the valves are the same size either but eyeballing it with a spare c10 engine I have the valve cover off the valves appear to be the same size.
