WillyP said:Generally they plug in to the ecu and read the gear position from that. Won't work on the C-10. Did you post in the wrong section?
:s_laugh: :85: )2linby said:I use the TOTLF and BOTLF indicator to determine my gear.
GFinCA said:WillyP said:Generally they plug in to the ecu and read the gear position from that. Won't work on the C-10. Did you post in the wrong section?
I thought so, too, Willy, but they apparently make a model that works with any bike (see the last entry on the 3rd page).
http://www.healtech-electronics.com/download/GIPRO-X_Application_list_en.pdf
It would be nice sometimes not to have to think what gear I'm in.
smithr-scad said:It tells you what gear your in. I never have seen one or used one. I just keep the rpm between 2000-10000 and switch gears as needed to maintain that.
